Warrior Float Stuck
Old 02-06-2006, 07:08 PM
Decimus's Avatar
Default Warrior Float Stuck
Hello, I just purchased a 96 warrior, and the float seems to be stuck. I havent taken the carb apart yet, and tapping on it doesnt seem to work. With the gas on, it will ride for a few minutes then bog down and start to die. But if i shut the gas valve off it'll pick back up and run fine. Switching back and forth is a pain. Ive never done carb work, so im iffy about taking it apart. Any help would be great, Thanks
Old 02-06-2006, 08:21 PM
trialsrider172's Avatar
if u have a manual for your bike, that should help a whole lot. or look for a diagram of your carb. other then that, take it apart in a place that is clean and you wont loose little peices. make sure u have a full can of carb cleaner. if your not comfortable doing it, give it to someone who is just to be safe.
mrtidy
02-03-2016 05:00 PM
wrencher82
09-28-2015 10:02 PM
Barnsnelbon
09-27-2015 03:07 AM
Bernhard
09-25-2015 12:45 PM
wrencher82
09-24-2015 03:39 PM
Quick Reply: Warrior Float Stuck
