Dumping Gas
Old Feb 24, 2006 | 07:27 PM
1STXTIMERX's Avatar
Default Dumping Gas
Alright.. when I got it... it was running a little rough, needed a little tuning. Well in the process of my 1st tune, It started to backfire. So Adjusted, well I took it for a ride and through the gears and hit 4th WOT and huge backfire. It blew off the tip of my silencer. I found that the rubber washer underneath the carb cap was torn apart, possibly leaking the extra air in causing the backfire. So while I was in the carb, I rejetted to 270. Put it back togather, and now an excessive amount of smoke is coming out.
I just noticed that my coolent bottle under the seat its slowely losing fluid, so most likey when it backfired I lost a headgasket perhaps? If the coolent gets down inside the jug what kind of damage or cleaning will I have to do? Will the coolen reach the crank case?
Old Feb 27, 2006 | 01:36 PM
1STXTIMERX's Avatar
Default Dumping Gas
Alright.. Took the head and jugs off, well first there was tone of gas in the pipes.. The head gasket was fine.. where do I go from here?
greg74
Sep 10, 2019 03:03 PM
blessedn09
Aug 9, 2015 03:07 AM
warrior3443
Jul 13, 2001 02:26 AM
tealboy
Dec 31, 2000 10:35 AM
tealboy
Dec 28, 2000 05:14 AM
