Banshee Plastic and Aftermarket Pipes: Will the pipes melt the plastic on the front fenders?
I am the proud owner of a new 2001 Banshee. I am looking at different aftermarket exhaust systems and was wondering if ya'll could give me some info. on how well different systems clear the front fenders. This question come up because yesterday I was looking at a Banshee with Pro Circuit pipes and the front right fender was cut around the exhaust. So I need to know if this is necessary for all pipes. I am looking at Pro Circuit, FMF, and Toomy's. Any info. is appreciated.
I have a pair of FMF Fatty's on my 99 Banshee and I have had no problem with them melting my plastic...It's a tight fit...but tight is good.
99 Banshee, FMF Fatty pipes, Power Core 2 silencers, K&N filter with pre-charger, yellow maier racing fenders, blue shockwears
www.geocities.com
www.geocities.com
ok, the reason why the fact that some pipes do rub and some dont is all yamaha's fault. not all of the motor mounts on the frame are EXACTLY the same, the motor is also mounting on rubber...that means that each motor will not sit exactly like another motor. so its not that the pipes are shaped differently or anything like that, i have two banshees and when i had inframe pipes on both, beither of them hit the fenders
Do the gnarly pipes give your banshee any better bottom end? Have you ridden banshees with other types of pipe to compare? I have a set of fatty woods pipes and the gnarly's weren't available when I bought the fatty's. How do the gnarly pipes stack up??? By the way my fattys did not melt the fenders.
Addict
Addict
I have aftermarket pipes (that I can't define the name). The fender had to be redrilled a bit more inside (where it is attached by the tube like bracket)so it is higher. That way, there's enough clearance, and no melting...but I don't think the pipes would get hot enough to melt it...rubbing, yes, melting...I don't think. A 4 stroke would, not a 2 stroke.
I haven't ridden a banshee with another kind of pipe so I don't have an answer for you. besides the other mods listed above I also down sized my front sproket 1 tooth. I did everything all at once so I am not sure what made the biggest difference, but there sure is alot more bottom end. I start off in 2nd gear when drag racing in the sand and this thing really hooks up.
07-07-2015 11:00 PM
