Help Warrior clutch adj.
Old Mar 13, 2006 | 12:35 PM
Putter700R's Avatar
Default Help Warrior clutch adj.
hello warrior owners,
i have a 2003 that my wife rides.
the clutch seem like its almost not there, it lets out with only a quarter of the lever let out.
when i pull it in its the last quarter that releases it.
the clutch strill grabs good and does'nt seem to slip
i have adj the lever with the recomended amount of end play.
is there another adj.??
or is it time fore new clutches
help!
Old Mar 13, 2006 | 05:10 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
the ONLY adjustment for the clutch is on the perch..
Old Mar 13, 2006 | 05:36 PM
recon99's Avatar
You can adjust it with the clutch arm (above the right side engine cover) taking it off the splines, and re-positioning it, and there's also some room for adjustment with the threaded part of the cable, where it attaches to the bracket at the engine.
The adjustment on the perch IS NOT the only adjustment for the clutch
Old Mar 13, 2006 | 07:28 PM
Putter700R's Avatar
does it sound like it nees adj. or new clutches??
Old Mar 13, 2006 | 07:51 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
just ride the quad and if you put it in a gear high and punch it and the rpms climb and your speed dont change. clutch is bad.
you can take allotta play outt athe cable with the adjustment on the right side where the cable is held on the clutch cover. shouldnt have to move the position on the shaft.
Old Mar 14, 2006 | 12:35 PM
Putter700R's Avatar
thats what i thought,
just wanted to here the opinion of other warrior owners to see if that clutch position is normal.
thanks
D.C.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
