raptor 700 overheating problems fixed
Old May 4, 2006 | 12:20 AM
hiller39's Avatar
Default raptor 700 overheating problems fixed
I just fixed the problem with my raptor overheating. There is a relay behind the tool compartment. It is the one closest to the tail-light on the exhaust side of the bike. Check the connections of the plug on the bottom. If you need to, bend the plugs inside with a screw driver to make a better connection. This fixed my friends raptor. On my bike I needed to fix a connector on the cord about six inched down of the plug right next to the fan relay (what I first talked about). It was two round connectors with a resistor looking thing at the end. I had to crimp the connectors to get power to the fan relay. This let the fan work like it should. You can use a meter on the fan relay and check that you are getting 12v on one of the vertical plugs and one of the horizontal plugs with the key on. Hope this helps.
toonces
Oct 16, 2019 12:11 PM
Stillonit
Aug 5, 2015 07:46 PM
sara durrant
Jul 6, 2015 05:32 PM
yambam13
Jul 4, 2015 01:49 PM
