Clutch Slipping
Old May 15, 2006 | 12:11 AM
mbmudder's Avatar
Default Clutch Slipping
Thats the thing in 5th gear it wants too go but won't it just slowly slows down and if you hit the gas it bogs.
Old May 16, 2006 | 02:11 PM
mbmudder's Avatar
ttt
Old May 16, 2006 | 09:39 PM
recon99's Avatar
Nobody can help you until you take it out and get a plug reading and see what the a/f ratio is like when it's bogging. Most likely it's too rich, but nobody can tell you that without you doing some work for yourself and getting it up to the bogging point for a few seconds, then cutting the motor and checking the plug color. Idling it wont tell you a thing unless the problem was at idle.
Old May 16, 2006 | 10:58 PM
mbmudder's Avatar
I know but i can only get it only too 4th gear 1/2 throttle and you said i needed to top it out.
Old May 17, 2006 | 12:18 AM
  #15
recon99's Avatar
The idea is to get it wide open for a few seconds. Even if it's bogging down that's what you need to do. It's probably bogging down from an extreme lean or rich condition, and a plug chop will show that. It doesn't matter how smoothly it's running, the plug should still take a reading.
Old May 17, 2006 | 01:31 PM
  #16
mbmudder's Avatar
It has a 5th gear though.In 4th gear anything over 1/2 throttle it starts to die and roll too and stop and this will not matter?
Old May 17, 2006 | 06:48 PM
  #17
recon99's Avatar
doesn't matter what gear, gearing doesn't affect jetting.
Old May 17, 2006 | 11:12 PM
  #18
mbmudder's Avatar
Ok.I put a new inline fuel filter and i blew threw both before i put it on and you could feel a difference.It did clean up some of the bogging but not much.There was some gas in the bottom of the airbox, wouldn't that mean it's too rich?
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
jbrewster94
Sep 23, 2015 04:16 PM
