plz help 350 warrior
Old May 29, 2006 | 12:26 PM
recon99's Avatar
Default plz help 350 warrior
Check the intake manifold for any cracks. They crack all the time, and can give a problem similar to yours if they crack in the right spot. At idle they're ok because there's enough vacuum to pull the gap together and seal the leak enough, but when the throttle gets cracked open the vacuum drops and the gap allows air to leak in and throw the a/f ratio way off.
Old Jun 1, 2006 | 01:35 AM
makeemfast's Avatar
i have ben having a problem with my 2001 yamaha warrior when i put it into gear it backfires blows a flame out of the exhaust and it runs sluggish in all gears please help me thanks
Old Jun 1, 2006 | 09:50 AM
recon99's Avatar
What does it do if you rev it up in neutral? Does it act like a rev limiter, or like it's running out of gas?
Old Jun 1, 2006 | 09:53 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
hey recon, you know yo uwant to get on AIM
Old Jun 2, 2006 | 03:59 PM
  #15
makeemfast's Avatar
more like its running out of gas
Old Jun 2, 2006 | 10:58 PM
  #16
recon99's Avatar
Check the intake manifold for cracks/tears. When it's idling push the carb side to side, up and down, and see if it changes the idle, or makes it cut out or misfire.
Old Jun 2, 2006 | 11:44 PM
  #17
makeemfast's Avatar
well my oil doesnt smell like gas so it shouldnt be the intake
Old Jun 2, 2006 | 11:51 PM
  #18
recon99's Avatar
That doesn't have anything to do with your intake. If you're going to shoot down my suggestions without trying them I can find better ways to spend my time.
Old Jun 2, 2006 | 11:54 PM
  #19
makeemfast's Avatar
im not trying to shoot down your suggestionds i was going to try your suggestion anyway b/c i really dont know what im doing
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
