Transmission slip grizzly 660
Yes they have a belt, you will need to drain your belt casing. If it gets water in it it will cause the belt to slip. Did it stall out in the water? I have a bruin also with a belt, I have never had a problem with driving through streams or crossing rivers, I have gone through some rather high waters but I have always creeped through them. The grizz sits up higher so either your going to fast or you going through to much water. my $.02
Jeff Roper
02-01-2022 11:48 AM
