Yamaha Warrior 350 need help starting
well try this then.. Run you a ground wire and hold it on the base of your starter...And run you a hot wire and touch it to the bolt on top of the starter..Were the stater wire is... And if it turns it over good. Your prob is in the wireing.. if it dont your prob going to have to buy a new starter...
charge your battery --- thats just enough voltage to make the starter turn a couple times.
if it still doesn't start after a 2A charge for 4-5 hrs... then tap the starter lightly with the handle of a screwdriver while trying to start it.
if it starts, then its the starter.. if it doesn't -- umm lemme know
I bought a 98 350 warrior, it hasa fmf exshast and performance racing clutch, ibought it and th eguy told me it needed a new cable ( it didn come with one)and when i was checkin the clutch, i pushed the lever on the motor (where the clutch cable connects) an di put the atv and gear and with the lever pushed in it should of been in neutral but it tried to take off. anyone can help me??
