4mm banshee stock porting
Old Jul 13, 2006 | 10:35 PM
superevil's Avatar
Default 4mm banshee stock porting
I ordered a stock crank and piston kit for my 2001 banshee. the guy accidentally mailed me a 4mm stroker/5mm long rod with the 795 piston kit and said i could keep it. Well i assembled it with stock porting and a spacer plate. I am FULLY aware that the stroker with stock porting is not optimal--but will not being ported with a 4mm stroker kill my reliability? I am told that it should be fine but i wanted to ask here to make sure
Old Jul 13, 2006 | 10:40 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
it will be fine.. but it's a waste of money not to port it... you could prolly get nother 8 hp out of it if you advance th etiming and port match/port it
Old Jul 14, 2006 | 08:24 PM
scramblered's Avatar
the stock porting on the shee is the worse job yamaha has ever let into a 2 stroke,a lot of potential
to gain there with the proper porting and pipe combo,it is a very detuned motor.
Old Jul 15, 2006 | 06:07 PM
bad350twin's Avatar
just look at it this way..... ride it like it is, then down the road have a repitable builder throw a mean high rev port job, maybe even triple port it then you will be flyin!
Old Jul 15, 2006 | 10:34 PM
SteveNB1's Avatar
Just went through that whole deal and the best results I've found was to loose the spacer plate and have the head machined for the piston clearance. The head work should be less than $100. Dramatic improvement, even with stock porting. I sank another $200 in a mild port job to get time timing close I was getting 63 hp out the dyno. Hell of a good time!
I highly recommend carbs. You can get the 26mm's to burn right but you have to be in the pipe at all times. To much low RPM trail riding will kill the bottom end bearings. Blaster 28mm's are good but some air strikers are the way to go. Then you will have a realiable set up. You will blow through a tank in no time.
After $10K+ later and not to mention the a loyal banshee owner for many years, I'm going 4-stroke.
Pehter
Oct 3, 2024 11:00 PM
dannytas
Sep 26, 2017 06:31 PM
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
