chipped gear/gasket
Old Jul 17, 2006 | 06:37 PM
fanninator's Avatar
Default chipped gear/gasket
ok a while back i chipped a tooth off of 2nd gear. im buying a new gear ($25) and gaskets ($80) a guy i work with said that they make a silocone gasket. its heat resistant and it comes in tubes for like $3. he said u use it just like gasket glue, is there any truth to this and if so does it work just as good? thanks -fanninator
Old Jul 18, 2006 | 01:28 AM
fanninator's Avatar
bump
Old Jul 18, 2006 | 05:00 AM
JLsparky7's Avatar
Use the glue in addition to the gasket, not in place of. Its just something to help the gasket seal a little better.
Yamaha makes stuff called yamabond er something. I just used it on my R6 when i put a new gasket on it. Just put some of the stuff around the crank case, put the gasket on the put more on the stator and screw em together.
2many2ride
Sep 27, 2015 04:35 AM
Elkaholic
Sep 6, 2015 02:44 PM
davewhistler
Mar 3, 2003 12:14 AM
mxzxracin
Aug 8, 2002 01:37 AM
SomeCrazyMexican
Jun 24, 2002 11:43 PM
