jet kit
Old 08-02-2006, 11:19 AM
Lukemysta66's Avatar
Default jet kit
i have an 89 warrior and i am going to run a straight pipe. i am buying a jet kit and i dont know wut kit should i buy? i dont have a lot of money so wut would be a good choice?
Old 08-02-2006, 02:50 PM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
Default jet kit
Forget the jet kit and just go to the dealer and get a few of the next size bigger main and pilot jets. That straight pipe idea is going to cost you power and it going to **** alot of people off. You need some back pressure for it to run at it's best.
Old 08-02-2006, 04:31 PM
Default jet kit
i dont think it robs any power because i started it up for a sec reved it up and it shook my whole bike no joke.
Old 08-02-2006, 04:46 PM
Default jet kit
OK luke, dont say you werent warned. Your going to burn the vavles out of it. Just cause it shakes is no sign of more power, it's more of a sign it's not running smooth. Good luck with it.[img]i/expressions/face-icon-small-happy.gif[/img]
Old 08-02-2006, 06:29 PM
recon99's Avatar
Default jet kit
I agree 100%. You started it up and it shook, so you didn't loose any power? LMFAO!!! Screw straight pipes, unless you have a highly built motor there's no way you'd ever benefit from straight pipes. Silencers are designed to evacuate more exhaust from the cylinder so you get the most air and fuel into it on the next stroke, obviosly that means more power. Like CamoKodiak450 said, not only will you lose power, you will also most likely damage your engine and your hearing. It's not going to sound good either, it sounds way too crackly and hollow.
Old 08-02-2006, 09:29 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default jet kit
like a COBRA ??
Old 08-03-2006, 12:57 AM
Default jet kit
so i should go with a silencer?? wut is a good one for not too much money?
Old 08-03-2006, 01:03 AM
recon99's Avatar
Default jet kit
The HMF is the cheapest i'd go, anything cheaper and they start to get kinda sketchy.
