2005 Yamaha bruin oil leak middle gear
Old Aug 21, 2006 | 10:23 PM
richgreen's Avatar
Default 2005 Yamaha bruin oil leak middle gear
Hi
Have a 350 bruin with a middle gear leak. Leak is under the boot before the u-joint.Leaks out engine oil.
Should I use some kind of stop leak or fix it.
Any sugestion for the fix?
Looks like there is a seal in there and a big JOB!
When pulled the boot of it had some sand & mostly oil water in it ...milkshake!
Help
mescha@cfl.rr.com
Thanx
Old Aug 22, 2006 | 12:20 AM
JLsparky7's Avatar
Welcome to the forums. I would do the lengthy repair, but i like working on stuff so thats just me. Take a look at this and see if you can pinpoint the gasket or oring that is leaking...
http://216.37.204.206/alba/Yamaha_OE...=13&A=309&B=17
Jmuddin284
Jan 19, 2026 07:16 AM
toonces
Oct 16, 2019 12:11 PM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
