Please help with Grizz reverse override?
Old Oct 10, 2006 | 04:31 PM
ridehard577's Avatar
Default Please help with Grizz reverse override?
I have an 03 Grizz and have by-passed the diff lock override and now I would like to by-pass the reverse override. I have searched this topic but haven't found much help.
Thanks in advance.
Old Oct 10, 2006 | 04:35 PM
squeege's Avatar
You need to look at the grizzhopper.com site.......don't let it confuse you....you just need to locate the green with white stripe wire and tap into it with a piece of wire and ground it out....
There are better ways....if you choose a switch or button....just check the site out
Old Oct 10, 2006 | 05:20 PM
squeege's Avatar
Sorry...but I was talking about 05' models.....03's should be similar but make sure for yourself
Old Oct 10, 2006 | 11:16 PM
Thanks for the help. I completed the job this afternoon and it worked great.
Old Nov 23, 2006 | 02:17 AM
willieb76's Avatar
How did it work out for you. I just bought an 05 Kodiak and might by pass the reverse override too are there any problems when you do this? Thanx
Old Nov 23, 2006 | 09:07 PM
It works great. No problems with mine.
Old Nov 23, 2006 | 11:53 PM
hondabuster's Avatar
Youll see the flashing "00" when in reverse, but its normal when the safety function of the reverse is over ridden.
I preferr the jumper wire to the existing over ride button. That way if a newbie gets on the safety still works ( things can get out of hand in a hurry, when full throttle in reverse with the rev limiter over ridden). Its also convienent, to use the existing button, and its placed in a good spot.
my 2 cents
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
poutlaw525
Sep 9, 2015 03:19 AM
toonces
Sep 5, 2015 01:14 PM
