Wolverine float bowl adjustment?
I changed my main jet to a 145 from 140 since it has a slip on FMF muffler and a K&N. While I was going to do that I thought it would be a good time to clean the carb. Good thing I did, it was pretty dirty. I got it all together but now it leaks fuel out of the drain. Seems like the float is not sealing? Maybe I bent the little metal piece on the float? To adjust it in the manual it says to bend it back. How do you know what is correct? I have seen that people used 1/8" clear tub or the actual float level tool, but how do you know where it should be?
Would this affect the performance?
The manual gives a measurement to reset it. Flip it over and measure from the flange the float bowl seats against. It is described in the service manual, do you have one? If not I can try to email you the page with the instructions.
01, 2003, adjusting, adjustment, bowl, carburetor, drain, float, height, level, upside, valve, wolverine, woolverinefloatvalve, yamaha
