Blaster Headlight Problem
Old Nov 13, 2006 | 11:15 PM
recon99's Avatar
Default Blaster Headlight Problem
Originally posted by: SBW
The answer is so simple, stop using full throttle. This may be a sign from above for you to slow down??? Have you seen any large swarms of locust's or any other odd things in the woods?
haha
you are joking, right?
Old Jan 28, 2007 | 10:12 PM
tmzg29's Avatar
whatever happened with this. I am having a similar problem.
Old Jan 29, 2007 | 10:54 PM
tmzg29's Avatar
Bump.........can someone please help with this.
Old Jan 29, 2007 | 11:39 PM
recon99's Avatar
did you try anything yet? i'm 95% sure it's the voltage regulator. My van did the same thing and that's what I narrowed the problem down to.
Old Jan 31, 2007 | 11:13 PM
  #15
tmzg29's Avatar
I have not tried anything yet. Only thing I have tried was replacing the bulbs without touching the glass. And this did not work.
Old Feb 1, 2007 | 09:12 PM
  #16
tmzg29's Avatar
No one else has had this problem? I guess I will start with replacing the voltage regulator and then go from there. .
Thanks recon 99
Frisky2050
Apr 9, 2020 11:19 AM
JoAnnS
Jul 23, 2015 02:18 PM
Captjay
Jul 23, 2015 12:33 PM
joeyupton
Jul 14, 2015 11:51 AM
tweeder
Jul 5, 2015 01:57 PM
