Grizzly 660 front diff. problem
Old Feb 13, 2007 | 11:59 PM
smokin529's Avatar
Default Grizzly 660 front diff. problem
Picked up a used '02 660 Grizzly. Everything worked great but the valves needed adjusting. I pulled it apart, adjusted the valves, put it together and now it runs great only it's stuck in 4 wheel drive with the diff lock on. I've gone through the wire plugs several times, cleaned them and used dielectric grease,replaced the three 4wd selenoids, checked the 4wd fuse and it still won't work. When I push the buttons, the servo doesn't make any noise at all. Any ideas? I must have something plugged in wrong.
Old Feb 14, 2007 | 10:31 PM
muddog660's Avatar
Sounds to me like the servo motor is stuck in the Diff-Lock position. The early model Grizzlys were either a hit or a miss with the servo motors. Sounds like you gotta miss...
Old Feb 14, 2007 | 11:13 PM
smokin529's Avatar
I'll pull it apart and check the servo motor.
Old Feb 15, 2007 | 02:44 AM
smokin529's Avatar
I have a miss for sure. Pulled the servo motor out and the diff lock was stuck. Did the battery thing deal that was explained in the manual to reset it,slid the gear over and put it back together. Works fine, but the motor doesn't sound right. I'll order a new one tomorow.
WilliamBos
Sep 30, 2015 08:08 AM
TLC
Jul 1, 2015 08:29 AM
blaze_master
May 26, 2015 11:18 AM
Biggieshortie89
May 26, 2015 08:01 AM
