Clymer repair manuals
Anyone use the Clymer repair manuals? I need to find out how to change the Swing Arm bearings in a 350 Moto 4. I don't know the year but it is older late 80's probably. I believe the bearings that I need to replace are in this schematic They are #2. The repair manual I was going to purchase is M4903. Is that the correct manual?
I like the Clymer manual. They provde detailed, step by step instructions on everything you would ever want to know about your ATV. Not sure about your schematic or manual. I got dumped when I clicked on it, but I know Ronniesmailorder.com has them - part # 27-M490 $31.95.
You can download and print the factory manual here. Click on "Tips & Tricks" on the left side, then click on sevice manuals, then select your quad.
Sevice manuals
Sevice manuals
Thanks for the replies. Bigdad, the repair manuals that are listed doesn't cover the Moto 4 from what I can tell. I don't know why the schematic link quit working. It worked when I first posted it. Here is the looong version of the url that can be copied & pasted;
http://houseofmotorcycles.bikebandit...ERA+MOTO-4.asp
http://houseofmotorcycles.bikebandit.com/partsbandit/oem_schematic_view~schem_dept_id~2392917~section_d ept_id~1~section_dept_name~OEM+%28Stock%29+Parts~d ept_type_id~2~model_dept_year~1990~model_dept_mfr~ Yamaha~model_dept_id~2392878~model_dept_name~YFM35 0ERA+MOTO-4.asp
No, the Moto 4 isn't the warrior. I was able to figure out how the swing arms were held in. One side bearing was gone, the other side looks ok, but since I went thru all the trouble to get it apart, I might as well change it to. I am going to a bearing shop today. Should be alot cheaper than thru a Yamaha dealer. The bearing is pretty standard in ATV's & motorcycles. It is a Koyo bearing #30203J.
I have owned 2 Clymer manuals in the past. Both would leave out some small things necessary to do the job right. Just take a look at the Clymer manual.....no-where near as thick as the factory manual.....and thats for a reason.....lack of information. Best way to go, if you cannot find a free downloadable factory service manual, is to stop in at your local dealership and obtain a PROPER maintenance manual for the atv. It will be more expersive that the Clymer manual, but well worth the extra cash outlay. Expect to pay around $50 if your dealer can't get you a deal on one.
