carb problems caused by ethanol in gas
Old Feb 28, 2007 | 05:49 PM
kaylie's Avatar
Default carb problems caused by ethanol in gas
I have been having issues with my carb in a 2001 warrior, the gas is just flowing through and dumping out the overflow tube. I changed the floatvalve and the problem went away but now it is back. I called the dealer and he seems to think it has to do with the amount of ethanol found in the gas, he also said he is seeing this problem 5 x more than he did last year. He is looking into an additive to help solve the issues with the gas. Is anybody else seeing this problem?
Old Feb 28, 2007 | 05:52 PM
kaylie's Avatar
Another note on this subject is that the dealer says the ethanol is causing water to build up in the carb which causes the issues.
Old Feb 28, 2007 | 08:05 PM
JDQuadRider's Avatar
No but if you're suspicious of the float being damaged by ethanol, see if there are brass floats available for your carburetor. Problem solved.
Old Feb 28, 2007 | 08:30 PM
recon99's Avatar
There must be something weird in the gas this year. I never had this happen to me before, and now while my float valve sticks on the edelbrock from time to time, even though all the moving parts are like new and have been cleaned twice. One other thing i was considering is the cold temperatures are screwing with things just the slightest bit, possibly something to do with metals expanding and contracting because of temperature changes.
Old Feb 28, 2007 | 10:19 PM
kaylie's Avatar
The float is fine, I even put a fuel filter in the line to help stop any dirt from getting in.
Old Mar 1, 2007 | 12:52 AM
JLsparky7's Avatar
If the float is working properly there is no way for the gas to come out the overflow tube. Some people have been having problems with there crankcase breather hoses with pressure building up. Do a seearch for that and maybe install one on your fue overflow.
neilbedwell
Nov 10, 2018 11:02 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
blaze_master
May 26, 2015 11:18 AM
