warrior clutch toughness
i was just wondering if there is any way that you can make a warriors clutch pull in easier. I know that lubing the cable does no good but If I were to go out and buy a whole new aftermarket clutch kit that comes with new clutch plates and cables and levers would that make it easier?
Changing the internal clutch components won't help, most clutch kits come with stiffer springs that will actuall make your pull harder. 3 things that can help big time are an ez-pull clutch perch and lever, a motion pro terminator cable, and a small modification to the clutch arm (the part that slips over the splines on the clutch shaft) The mod on the clutch arm is to cut in half and weld in a centimeter or so extra to give it some extra leverage. Those 3 things will make a huge difference in the pull.
