450r vs. 700 Raptor?
Old Jul 2, 2007 | 10:11 PM
  #31
GregW's Avatar
Default 450r vs. 700 Raptor?
I have seen several vids on you tube between the yfz450 and the raptor 700r. I don't know how the trx450r compares, but the two yamahas seem to run about neck and neck. One thing you have to remember. the raptor is designed as a trail burner, while the 450's are designed to race on the track. Maybe the raptor has a much larger engine, but the stock compression of a raptor is 9.2. I don't know what the trx450r's ratio is, but the yfz has an 11.4 comp. ratio. that makes up for a lot of the displacement advantage that the raptor has.
Old Jul 4, 2007 | 04:30 AM
  #32
GRAY's Avatar
my honda450r will out run the new 700
Old Jul 4, 2007 | 04:37 AM
  #33
GRAY's Avatar
I LIKE THE NEW raptor 700 THEY RUN GOOD BUT MY HONDA 450R WILL STILL HANG WITH IT...............................
Old Jul 5, 2007 | 02:15 PM
  #34
crazy1291's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: GregW
I have seen several vids on you tube between the yfz450 and the raptor 700r. I don't know how the trx450r compares, but the two yamahas seem to run about neck and neck. One thing you have to remember. the raptor is designed as a trail burner, while the 450's are designed to race on the track. Maybe the raptor has a much larger engine, but the stock compression of a raptor is 9.2. I don't know what the trx450r's ratio is, but the yfz has an 11.4 comp. ratio. that makes up for a lot of the displacement advantage that the raptor has.</end quote></div>
only 11.4 on the yfz???? the o4 had 11.9 if im not mistaken, and i've never heard of a manufacturer bumping down the comrpession on a quad, more like 12.0 or 12.5 which is what most 450s run
the 450r is 12.5:1 compression ratio
a new piston doesnt cost all that much- just imagine a 13.5:1 compression 700 raptor, the 450s wouldnt stand a chance
Old Jul 8, 2007 | 12:42 PM
  #35
raptor 700r's Avatar
well have not done much drag with mine but i did race a ktm dirt bike 250 that is built from to to bottom its a bad bike and to only think it ways 238 lbs and my stock raptor 700 ways 398 lbs in every gear i am side by side with him he does not pull me and i do not pull him its awesome
Old Jul 8, 2007 | 07:11 PM
  #36
Recockulous's Avatar
Me and two of my friends just bought two raptors and a yfz. We've spent the last 4 days riding in Florence, OR and Winchester bay, OR. Both stock the 700 pulled on the 450 on flat or up a dune, not by much but just enough.
Old Jul 8, 2007 | 09:17 PM
  #37
Fulltiltrider's Avatar
deleted
  #38
deleted
Old Jul 9, 2007 | 12:17 AM
  #39
GRAY's Avatar
honda trx 450r 06 will beat the 07 raptor.............................. my will..............
Old Jul 9, 2007 | 07:28 PM
  #40
LotusPosition's Avatar
It always amazes me how many people can't or won't comprehend the title of a thread.
