Will my belt cause a vibration when its going bad?
Old Jun 10, 2007 | 11:09 AM
xcbandit's Avatar
Default Will my belt cause a vibration when its going bad?
I have a 04 Bruin 4x4 and it started vibrating of 15mph, the more gas you give it the more it vibrates.
I also thought maybe its the u-joint going to swing-arm.
Old Jun 10, 2007 | 01:47 PM
Yamahaman06's Avatar
i dont think it be the belt bore likey the u joints for the shaft. hth
Old Jun 10, 2007 | 04:37 PM
xcbandit's Avatar
are they hard to replace?
Old Jun 10, 2007 | 07:18 PM
upnort's Avatar
Could be either.
To check U-joint. Make sure there is no pressure on it, then grab both shafts or on the joints and check for movement, there should be none.
If there are pieces missing out of belt it will viberate, also of there are flat spots where it rides in the sheaves it will viberate. Best way to check is to pull clutch cover off & remove belt. Can lay it on a flat surface & check for flat spots. Inspect for any deformation, cords etc.
Old Jun 10, 2007 | 07:38 PM
xcbandit's Avatar
well ill give you a update when i check it out. Thanks
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
