help me out banshee guys!!!!!!!!!!!!!
Lets see. 270 mains---ok, fine. Stock needle position----ok fine, maybe try 1 clip richer . No bottom end power????? Stock pilots??????????? Try #27.5 or #30 pilots to richen the idle to 1/4 throttle circut. ALL circuts need to be richened not just the mains, unless you like your shee to run like **** except at w.o.t.
What ever speedy. Go to the BHQ and see what other people are running for jetting. My 99 runs 320 mains in the summer, 340 in winter and #30 pilots year round, with air screw adjustments per season {i ride at 600 ft above sl}. All it has done is a pro flow and procurcit pipes on the 99. As a matter of fact, when I got the bike, it had a hard stumble at idle to 1/4 throttle {everyone claimed it was a rich stumble]. I went 2 sizes up in pilots and guess what? The stumble disapeared, and I gained some low end power, { I didn't have to rev it to the moon to take off from a dead stop}. Stock a banshee uses 200 mains, and #25 pilots. Adding pipes makes your main jetting sizes 7 {270} to 14 [340] times larger than stock. But 2 sizes bigger on pilots is "way too much"????????????????????You can look at all the vids you want, I have 2 banshee's in my garage, and I'm not blowing smoke up anyone's a$$
