SPROCKET TROUBLE
Old 03-27-2008, 03:40 PM
king_kval's Avatar
Default SPROCKET TROUBLE
Anyone know how i can go to a 38 tooth sprocket on the rear of an 04 660 raptor.The lowest thye make is a 40 tooth.Can i change the hub.Will something else work.Please reply.
Old 03-27-2008, 06:02 PM
TomM's Avatar
put a bigger one on the front
Old 03-27-2008, 06:20 PM
king_kval's Avatar
I went to a 15 up front and it helped alot ,but id like to try a 14/38 and i cant.There must be some way to change it.
Old 03-27-2008, 06:30 PM
TomM's Avatar
Unless you find someone who sells a 38 it wouldnt be worth the effort of modifying something. The difference in going up one tooth in the front or down 2 in the back is exremely small.
Old 03-27-2008, 07:20 PM
king_kval's Avatar
ok thats what i was wondering,if it would be worth it.thanks for the advise.
Old 03-27-2008, 09:02 PM
ich4bdm's Avatar
i didn't know 660 had a 40 tooth rear? my 700 came 14/38 stock. i put a 36 on the rear. if they make smaller for the 700, they have to make smaller for the 660. try Renthal.
Old 03-27-2008, 10:38 PM
king_kval's Avatar
I tried every brand that you can think of, and then some and no one makes anything smaller than a 40 tooth sprocket for the rear.
Old 03-27-2008, 10:51 PM
Terrellster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ich4bdm
i didn't know 660 had a 40 tooth rear? my 700 came 14/38 stock. i put a 36 on the rear. if they make smaller for the 700, they have to make smaller for the 660. try Renthal.</end quote></div>
Is the Sprocket hub interchangeable on the two of these? If so ebay a hub.
Old 03-27-2008, 11:01 PM
TomM's Avatar
I took a look I didnt see any smaller than 40 either. If you go to DennisKirk.com and look up any part it will have a link to other machines that part will also fit, its usefull for this sort of thing. The sprokets I looked up for a 660 dont specify that they will fit a 700. They will fit a Warrior but only 89 and up. They sell a 38 for a 87-88 Warrior but it wont fit a newer Warrior or a Raptor. Evidently Yamaha changes thier hub patern sometimes.
Old 03-27-2008, 11:19 PM
Patches3489's Avatar
http://search.ebay.com/search/...th+warrior&category0=
copy and paste that in the address bar. it a front sprocket.
Quick Reply: SPROCKET TROUBLE
