Raptor exhaust heat, too much?
Old Apr 24, 2008 | 12:41 PM
oblytr8's Avatar
Default Raptor exhaust heat, too much?
The Raptor 660 have, I purchased with a full FMF exhaust already installed. Since I have ridden it, I have noticed the heat on my right leg from the exhaust is quite hot, more so than I remember feeling on any other 660, or 700. It was to the point where I could not comfortably ride without boots, the heat was a bit much. Is this normal? Anyone out there with a full FMF system seeing this as well? Should it be running this hot?
Old Apr 24, 2008 | 03:03 PM
Raptor450's Avatar
You must be running lean. We measured the pipe temp on a 450 that had the same problem and his was around 700 degress F. I have a pipe on my 660 with no heat shield and mine doesn't get that hot, I would even be comfy riding in shorts.
Old Apr 24, 2008 | 03:17 PM
oblytr8's Avatar
I thought I may be running a lil lean, especially after reading the carb adjustment thread on here. Performance has been excellent, the only prob I have had is the heat, and it was more of a concern, than a problem.
Old Apr 24, 2008 | 11:56 PM
Raptor450's Avatar
Yeah a lean engine runs better than a rich one, but not for long! Did you re-jet it when you installed the pipe? If so waht jets and what filter/airbox lid combo do you have?
Old Apr 25, 2008 | 08:25 AM
oblytr8's Avatar
I never rejetted it after installing the pipe. When I purchased the ATV, the pipe was already installed. The previous owner did say that when he installed the pipe, it didnt seem like it was getting enough air. He drilled holes into the top of the airbox (WTF?!), to give it more air.
Old Apr 25, 2008 | 12:11 PM
Raptor450's Avatar
Oh my God!!!!!!! If he didn't rejet it, you better do so immediately and cross your fingers that you haven't done damage to your piston and cylinder walls!! Anytime you add more airflow, you need to rejet accordingly.
Old Apr 25, 2008 | 03:57 PM
oblytr8's Avatar
By "rejetting" do you mean adjusting the air mixture? Or physically removing the jets, to install larger ones? I understand the concept that an increase in air must be balanced with fuel as well, but can't this be done by adjusting air mixture to the richer side? Will it not adjust enough to compensate for additional airflow?
Old Apr 25, 2008 | 05:23 PM
oblytr8's Avatar
I just spoke with him, and no, it was never rejetted. So the question now is, how do I go about doing so? Can I just pick up a rejet kit at my yamaha dealer, or consult FMF to see what they recommend for the exhaust? FMF's recommendations, is a main jet of 145/150, stock needle, needle position = 3rd, and the fuel screw at 3. This sound correct?
Old Apr 25, 2008 | 10:24 PM
Raptor450's Avatar
Yeah you need a jet kit, or just buy a 145 and 150 jet, make the necessary adjustments, and save yourself some money.
STLyamwar
Jul 25, 2020 04:44 AM
Aug 25, 2015 11:16 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
