Skid Plates
Old Jul 1, 2008 | 11:36 PM
CraZySteve's Avatar
Default Skid Plates
<div class="FTQUOTE"><begin quote>Originally posted by: immerume2
So I asked and he replied.
Q[img][/img]lease advise Aluminum thickness grade and mounting info.
A:.125, 6061-T6 Aircraft Grade Aluminum. Rubber coated steel clamps will not loosen or rattle Thanks!!!
Looks like they are on the thin side like at 1/8". The thing I know nothing about is the 6061-t6 grade. Is that better or worse than 5052? Thanks.</end quote></div>
1/8 = 0.125 and I'd look for thicker if you can... I can take pictures of my GYTR Belly skid on my Grizzy... it has taken a beating... but there are some good gouges in its..
6061-T6 is better if the plate is totally flat and doesn't need to be bent... is not that formable, somewhat brittle due to heat treating and not as good as far as corrosion goes.. I chose the 5052 because my metal shop can use their shear for up to .290 if it is 5052 and only 0.150 if it is 6061 as 6061 is about 25% stronger than 5052. 90% of the aftermarket skids made by reputable sellers are made from 5052.
Old Jul 1, 2008 | 11:37 PM
CraZySteve's Avatar
Default Skid Plates
<div class="FTQUOTE"><begin quote>Originally posted by: faponce
WHen are you going to quit talking up those skids and make me some[img][/img]</end quote></div>
You talkin to me? [img]i/expressions/beer.gif[/img]
Old Jul 2, 2008 | 04:16 PM
faponce's Avatar
Default Skid Plates
Yes, ''CraZy Steve'' I was talking to you but I was just giggin you.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 2, 2008 | 04:31 PM
CraZySteve's Avatar
Default Skid Plates
Yes, ''CraZy Steve'' I was talking to you but I was just giggin you.[img][/img]</end quote></div>
I know hence the reason I hoisted a Beer [img]i/expressions/beer.gif[/img] [img]i/expressions/beer.gif[/img] [img]i/expressions/beer.gif[/img]
lonerider856
Oct 13, 2023 03:45 PM
Oct 10, 2015 10:20 AM
tysonbully
Sep 28, 2015 02:30 AM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
