Timberwolf question...... Anyone know what is going on?
Old Jan 18, 2009 | 11:50 PM
Mattf2147's Avatar
Default Timberwolf question...... Anyone know what is going on?
92 Yamaha Timberwolf 2x4. I have been eating starters. I put a new solenoid and starter on my atv, along with a new starter button. Question is, After I push the start button, the motor starts right up, but when I let off the button, the starter keeps on running and burns them up. I dont know what to do. There is a little black plastic box next to the solenoid and rectifier. I read in the manual that is a starter cut off relay. Can anyone confirm that for me? I would appreciate anything I am ready to ride this thing!
Old Jan 20, 2009 | 02:14 AM
cherokee99's Avatar
you would have to test the circut with a volt meter, but im pretty sure that is the cut off relay. it could also be the brushes and mechanism in the starter that are not disengedgeing when the motor starts running. easy way to rule that out is to start with the pull rope. if it dose not engedge the starter then it is most likely the relay switch that has gone bad.
good luck!
Old Jan 20, 2009 | 09:23 PM
Mattf2147's Avatar
Ok, well thanks for the reply, I will check into that. Do you know of a good place I can buy a cut off relay? Very new to 4 wheelin and have no idea where to look
wildbill59
Jun 22, 2015 09:22 AM
wildbill59
Jun 9, 2015 02:28 AM
atc350
Jun 27, 2000 11:48 AM
95TimberWolf
Mar 14, 2000 10:33 AM
Brian_Kimmel
Aug 9, 1999 02:24 PM
