Warrior Advice
Old Apr 4, 2009 | 08:42 PM
NewportHillClimber's Avatar
the only cdi that i have found that you can put on a warrior that has the same timing advance is off a trx250x. it uses less wires so you can do away with all the relays and crap on the warrior and the advance rpm is lower at 2800 as opposed to the warriors 5000 rpms
Old Apr 27, 2009 | 07:50 PM
denko's Avatar
i have a 96 warrior that i just found out that the darn cdi is bad for a second time. I saw that you said a trx250 cdi will work? how are the connectors do they match up? can you give me more details on this. I would like to try something else besides another oem. Thanks alost for the help.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
