Warrior reverse issue
Old Mar 28, 2009 | 05:47 PM
zoolx75's Avatar
Default Warrior reverse issue
I am lookng at buying a 01 Warrior. The machine is in great shape, not used much and still has the original tires on it (only 25% used). When you put the machine in reverse, back up a little then pull in the clutch, reverse will not disengage immediately, it keeps rolling backwards. A couple of times I even had to pull on the brakes to get it to stop / disengage. Any ideas as to what this is caused by? Expensive or cheap fix? Thanks for any assistance.
Old Mar 28, 2009 | 09:59 PM
UTU's Avatar
UTU
When you use the clutch? Reverse works when tranny is in neutral???? Might be a clutch issue????
Old Mar 28, 2009 | 10:09 PM
zoolx75's Avatar
From any gear including neutral, from a full stop, pull in the clutch, select reverse gear, let out the clutch and back up. When it is time to stop backing, when you pull in the clutch, the machines keeps backing up as if you had not pulled in the cluch at all for 4-5 seconds, then usually eventually it will disengage, sometimes however only with the help of the brake. This does not happen in any of the six forward gears.
Thanks.
Old Mar 29, 2009 | 12:45 PM
beefy46172's Avatar
Loves To Ride!
Something I have noticed on my Warrior is when the clutch needs adjusted reverse if the first place it shows up, sounds like you may need to put some slack in the clutch cable.
Old Mar 30, 2009 | 06:00 AM
chrisd0729's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: beefy46172
Something I have noticed on my Warrior is when the clutch needs adjusted reverse if the first place it shows up, sounds like you may need to put some slack in the clutch cable.</end quote></div>
Ditto- same here on my 02 Warrior.
Old Apr 7, 2009 | 09:47 PM
zoolx75's Avatar
Thanks for the info, but I ended up buying an old DS650.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Reactant
Jul 16, 2015 10:29 PM
Scottma518
Jul 10, 2015 12:42 AM
