2001 warrior 350
Old Mar 29, 2009 | 09:27 AM
UTU's Avatar
UTU
Default 2001 warrior 350
When i nail the throttle in neutral and from idle the motor dies. I can just push the throttle a lil slower and revs up no problem. Just when I nail the throttle from idle motor dies. Been working on the warrior for a friend. So far new starter,battery,rebuilt carb. Rode several times seems to run down the road/trails fine. Looking for a stock baffle or muffler there is no baffle in the muffler now could this be the problem????? Any ideas??
Old Mar 29, 2009 | 12:41 PM
beefy46172's Avatar
Loves To Ride!
Check the accelerator pump in the carb. The spring is known to hang up. Even better, replace it with a spring out of a click style ink pen that looks like its about the same diameter.
Edit: Also, I believe I still have my stock muffler, PM me if you are interested
Old Mar 29, 2009 | 06:23 PM
laxattack99's Avatar
Yea myy warrior does that too. Usually it happens when i first stsrt it up nd i dont let it warm up long enough. If i oin the thottle bedore its warmed up itll die. Does it do it after uve been riding for a while?
Old Mar 29, 2009 | 07:34 PM
JLsparky7's Avatar
Sound like your idle jet is rich.
Old Mar 30, 2009 | 08:43 PM
Skatike27's Avatar
I have the same problem. I wound up rebuilding the carb and then adjusting the needle. It still occasionally bogs out from time to time, but not nearly as often. If someone has a fix, let me know.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
