Rear Shock for Warrior 350?
I picked up 1987 Warrior 350 and the rear shock is gone what other models shocks will fit a warrior?
How hard is it to redo the tranny on a warrior? Should i buy stock tranny parts or afterkarket? It seems like it does not wont to go in 5th gear or when it does it slips out so going buy the book i bought i should need to replace the 5th gear wheel in the trans. It looks hard to put togeather though.
a rear shock from another warrior, blaster or banshee will work i believe, dealing with the tranny on warriors isnt to bad but it can be a pain since its a 6 speed with reverse, your shifting problem might just be a bent shift fork or something wrong with your shiftdrum maybe, warrior trannies are bulletproof i hardly ever hear about warriors transmissions having gears break or anything.
It goes into reverse and like i said when in 4th gear or so trying to get into 5th takes a few tires heck im not really sure if ive ever had it in 5th, 6th gear.
Thanks for your help
