350 warrior problem. knocking noise.
hello just wondering if any body has run into this problem.i traded a dirt bike for an 96 warrior decent shape.had some carb issues.i got them straightened out and changed the oil and filter once done i now have a rattling noise come from the inside of the motor did not do this before the oil change.have serviced my other machines never had this happen.i am an auto and truck tech been doing it for 30 yrs.any help would be appreciated.thanks john.
warriors have a timing chain adjuster on the side of the cylinder that automatically adjusts it, so if its loose then the chain is worn out and or the timing chain guides are also, if its like a slaping sound then thats prolly a timing chain, ticking sound most likely is valves, if it is knocking sound then thats usually a worn rod.
worrior knockin
okay finally got some time to check out removed plastics and rocker covers found intake rocker jamb nut missing and screw backed off.so got a new nut and got a clymer manual to check for spec but i cannot find any speck for valve lash.can some one post the spec thanks john.for all your help thanks .oh found the nut in front rocker cover a little beaten up.
ive actually had that happen before you dont need to take the head off, you should be able to pull the cam to get it, this is one of those times when u need a long magnet one of those skinny 2 ft long ones and fish around, mine has fallen off before and i was so close to getting it, but i ended up havin to pull them cam and there it was nestled in a corner, good to hear u got lucky and got it out, i think stock valve lash is .002/.004 intake and .006/.008 exhaust so somewhere i between those and it should be good.
