pressure wash or not????
Old Apr 27, 2009 | 09:28 PM
dwcth's Avatar
Default pressure wash or not????
I just got my project blaster apart... is it ok to use use a pressure washer on the head and cylinder???? if not... what is the best way to clean??
Old Apr 27, 2009 | 10:57 PM
NewportHillClimber's Avatar
you can pressure wash it all you want. just when your done blow it all dry with compressed air and spray the cylinder walls with wd-40 so they wont flash rust
Old Apr 27, 2009 | 11:48 PM
91Warrior357's Avatar
this, or in a parts washer is where i clean stuff like that
Old Apr 28, 2009 | 09:24 PM
flyinscrammy's Avatar
I have a friend that just put his in the dishwasher....... Cleaned it right up. You just have to get it out and dry it immediately.... Either that or scuff the surface rust off when you get home from work!!!!
Old Apr 29, 2009 | 05:31 PM
dish washer? thats awesome. id hate to see the grime that would be in mine. lol
Old Apr 29, 2009 | 07:06 PM
DETROITBOMB's Avatar
Default Dobech Fuel Programmer Raptor 700
I have a full Dr. D pipe on my 2006 Raptor 700 with a K&N air filter and a Dobech programmer. I set the programmer for the "open" pipe which was in the manuel and it runs good. I was wondering if anyone has the Dobech programmer with a full pipe and what number settings they have it set for, and how they run at that setting? Thanks in advance, please give me your imput.
Jim
Old Apr 29, 2009 | 07:09 PM
Default Opps
did mean to do that...
Old May 1, 2009 | 10:24 PM
headpressure's Avatar
This is my opinion regarding pressure washing and it's based on the fact that I design and build them.
You can't beat pressure washing greasy assemblies with a pressure washer especially with hot water and a good quality degreasing cleaner.
Disassembled parts can be washed in a parts washer or even a dishwasher as was mentioned since this does a more through job but most people don't want dirty engine/drivetrain parts in their dishwasher.
As for the entire machine I would recommend a garden hose with warm water and soap with a sponge. I don't pressure wash my whole machine.
BTW most people put way too much emphasis on pressure and don't consider water volume like those cheap little washers that are available.
JMO
Alex G.
Sep 11, 2017 11:38 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
bigred20653
Sep 19, 2015 02:11 PM
