Yamaha Warrior Will Not Fire Up.
#22
Hey mine is having the same problem I have good compression new carby and a spark but it looks a bit weak compare to my other bikes but has new coil lead and plug could it be my stator
#24
Fit a new plug and check it sparks. If that doesn't work, clean the carb out. One other problem, rather peculiar to Yams, is a cracked inlet manifold, so check that too. If it still won't fire up, re-set valve clearances, then check compression. If below 90psi, it is getting time for a top end rebuild.
