'99 Warrior 350 Need help
Old Jul 19, 2009 | 04:14 PM
mamesteco's Avatar
Default '99 Warrior 350 Need help
I'm new to the ATV scene. Just bought a used 1999 Warrior, completely stock and already have a question for you.
It ran good for the 1st couple tanks of fuel. Now it will bogg out and sputter when I rev it up. I've search this forum and have disconnected the parking switch, thinking that was the problem. It is not.
I've cleaned all electrical connections and grounds, not the problem.
Took the carb off, looks good and clean inside.
It does run good sometimes, not very often. Seems to do it after about 10-15 mins of riding.
Ideas anyone?
Old Jul 19, 2009 | 06:36 PM
Terrellster's Avatar
I'm guessing a CDI problem if it runs good til it's warmed up..... if I'm reading your post right.
Old Jul 19, 2009 | 09:30 PM
slopoke76's Avatar
yea sounds def electrical. If not the cdi try checking the pickup coil resistance when hot.
Old Jul 19, 2009 | 10:48 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
$50 says it's your parking brake.. if it revs in neutral then that's not it.. Also If you don't plug in the 2 connectors it will still think the parking switch is activated
Old Jul 19, 2009 | 10:56 PM
slopoke76's Avatar
does the 99 have the park brake switch? I thought it had to be newer. I could be wrong though.
Old Jul 20, 2009 | 10:34 AM
Kevin R.'s Avatar
My "97 has the park brake switch.
Old Jul 20, 2009 | 08:35 PM
yamahawarrior1986's Avatar
did u disconnect the parking brake or cut the wires? i had the same problem. i cut the wires that go to the parking brake. i dont know if it matters, but its worth a shot.
Old Aug 14, 2009 | 08:31 AM
350war's Avatar
make sure your gas tank vent is not plugged. had the same problem found my vent tube was plugged with greas from the stearing shaft
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
