97 Warrior carb?
My 97 Warrior had been acting up for a few days. It had been sputtering, and cutting off on me while idling.
I noticed there is huge crack in this rubber tube from the carb to the case, that after I covered with electrical tape, worked fine.
Any idea what it's called, or even better, where can I get it?
your help would be greatly appreciated.
Oh, by the way, what motor oil do you recommend?
Carlos
Carlos
Yea it's the carb boot and you should be able to get one from any online atv parts dealer or ebay. As far as oil, just make sure whatever oil you get is recommended for a wet clutch. I just use the motorcycle oil from walmart, because the only other place to get oil around here is the yamaha dealer and I don't like him so...
GregM
Mar 6, 2018 06:53 AM
