I need some help my blaster is running real bad at low rmp.
When I first got the blaster it would start with the first kick now its wont start at all if its been siting for more then a day or two. I had to get pulled with my friends four wheeler and ride with it in gear in till it started. It didn't take to long only pulled it for about 30ft. But I tried kicking it a number of times and it didn't stat. After it got a little warm it would start right up when I kicked it. One more thing is I know 2 stroke are not to good at lower rpms but mine is really bad. With the throttle wide open it would pick up very slowly but as soon as I hit higher rpms it takes off. Its real hard to climb a little hill with out it stalling. I drove it for a little more then 3 hours today and besides the low rpm problem it ran great. I'm just real confused because if I rev it high and dump the clutch I can do burn outs on pavement but I can barely climb a little hill ?
