warrior carb problem
Old Nov 15, 2009 | 06:45 PM
camperloco's Avatar
Default warrior carb problem
hello,
i have a 94 warrior, i just had the carb cleaned and a new rebuild kit put on, the atv will start but wont idle, only can get it to start or idle (high) with full choke on, as soon as i move the choke it dies or needs to throtttle to keeep running will not idle with choke off.
please any suggestions on what to look for, or how to set the idle screw i tried turning this in or out and didnt see any difference.
thank you
Old Nov 19, 2009 | 10:06 PM
camperloco's Avatar
any one have ideas, or problems with choke? must just be me, this thing only idels with full choke.
Old Nov 20, 2009 | 11:42 AM
Racingbrat's Avatar
Plugged slow jet will do that clean carb again
Old Dec 9, 2009 | 11:00 PM
canoeman43's Avatar
Default check the boot
check the boot between the carb and the head,its not uncommon for it to be cracked,if it is (whitch it sounds like it is)the motor is sucking in air and itll never run right or idle.
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
