moto 4 ?
Old Dec 28, 2009 | 08:31 PM
  #31
wendal's Avatar
thanks.
My throtle seem to be stuck. I took it apart at the handle bars and tooki it apart. It does not seem to be stuck their. Has anyone had a cable freeze like this or is it in the carb? If in the card how do I go about fixing? Take it apart and clean or try to replace?
From the pictures I have looked I think the bike is a YFM 225. What do lyou think?
The serial number is rubbed off the frame.
Can you tell me why their is only the electric start? no pull or kick backup. Can this be added?
I found a switch assembly on ebay. So in a couple of days I hope to have the assembly and a battery and will see what happens.
thanks again
Old Dec 28, 2009 | 09:17 PM
  #32
Terrellster's Avatar
I think TLC is right. The lever in this picture is used thus - All the way down is High I think, Center is low, and all the way up is reverse. (I could have the high and low swapped, but it's been a very long time since I've ridden a bike with this set-up) There was one instance I rode one that only had 2 positions, forward and reverse.... But find Neutral and then use the lever as shown. Squeeze first, then move lever up, down or whichever position needed.
Old Dec 29, 2009 | 11:07 AM
  #33
TLC's Avatar
TLC
Clean your carbs for sure,Here is instructions of cleaning a slide carbhttp://www.ripperd.com/ftp/admins/carb_rebuild/ but your ATV will be a bit different,but no matter the important things to clean on both is the main and pilot jet,choke plunger and pilot air jet.
Here is your carb Main is #19,Pilot jet is #18, Pilot air Jet (The one you count turns) #16 and choke Plunger #9
Old Dec 29, 2009 | 08:47 PM
  #34
wendal's Avatar
thanks hope to have time to take it apart tomorrow..
Old Dec 29, 2009 | 09:59 PM
  #35
TLC's Avatar
TLC
Oops just notice the link did not work, Disassembly and Cleaning of a Mikuni Round slide Carburetor
Old Dec 30, 2009 | 09:12 AM
  #36
wendal's Avatar
thanks again
might be a stupid question but can I use the same picture to work on the card on the moto 4 80cc?
thanks
Old Dec 30, 2009 | 05:09 PM
  #37
wendal's Avatar
I got the carb cleaned up today. It looked like their was some varnish in the carb and the tank.
Once I get the starter switch and a battery I will try to fire her up.
I am going to try to clean the carb on the moto 4 80cc. It was not as bad as I thought.
wendal
Aug 3, 2024 10:03 PM
scman843
Jun 18, 2017 10:21 PM
fredrikrosen
Oct 29, 2016 07:56 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
