Yellow liquid? What is it?
Old Jan 18, 2010 | 08:31 PM
2003blaster's Avatar
Originally Posted by Thundare
You cant go and put any regular engine oil in a quad man, the engine oil doubles as the transmission fluid. You might have just burned up your ride bro.
Well I think the crank case was cracked or something already. Like, the gas really leaks if you leave it in the on position.
It still runs...
My dad was all in a hurry to ride cause it was starting to rain...
Old Jan 18, 2010 | 08:41 PM
Thundare's Avatar
Gasoline does not go to the crank case, it goes to the carburetor. If its leaking out check the over flow tube on it, If it is leaking that could be stuck floats.
Old Jan 19, 2010 | 08:18 PM
JP Lava's Avatar
Default oil cooler?
Hey Blaster, I used to have a blaster and I don't remember any fluid things under the headlight. Regardless, look where this fluid is coming from EXACTLY and it will shed more light toward an answer. .. ALSO, how much oil did you put in? Did you fill it up to the top of the fill hole? If you filled it to the top of the fill hole, STOP NOW and get an owners manual. It doesn't hold that much oil.
Old Mar 15, 2010 | 11:57 AM
OHIOKFX's Avatar
did any body check brake fluid line splits under light
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
01ssls1
Sep 21, 2015 12:23 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
toonces
Aug 5, 2015 05:55 PM
Shifts
Jul 3, 2015 07:59 AM
