How long should it take to install an axle on a Raptor?
It's super simple.. You could do it yourself in less than 30 minutes.
Here are the steps. A floor jack would come in handy when you get the wheels/hubs off.
1) Remove both wheel hubs with the large single nut on both ends of the axle.
2) Loosen the 2 stock axle nuts.
3) Remove the brake caliper (2 bolts if I remember correctly) last, you may need to use the brake in order to stop the axle to take care of steps 1 or 2.
4) Loosen chain and remove it from the rear sprocket.
5) Pull old axle out of the left side being careful not to mess up the bearings or seals in the axle carrier.
6) Take the sprocket off of the old axle and put it onto the new one.
7) Reassemble.
This list may not be all-inclusive. If I missed any steps, someone feel free to point them out.
7) Reassemble.
bash, I just put a LS axle in my Raptor last week or so, and I didn't take my chain or sprocket off at all! You don't have to do this. I started to when I noticed that once you take the axle nuts off that the whole thing just slid right out no problem. And then I just slid the new one in. The sprocket and chain never moved. Hope this helps. Also BlurReptile, I think you should do it yourself and save some $$$. It's wasy easy, just get a couple of large pipe wrenchs for the axle lock nuts and she's easy as pie from there!
The lonestar axle took 20min. to install with air tools. First loosen the axle locknuts then raise the rear end of the machine with a jackstand, remove the rear wheels, remove the rear hubs, remove the axle locknuts, tap the end of the axle with a rubber mallet and it will slide right out. Everything else (sprocket hub, rotor hub) will stay in place. I would recommend using never seize or at least some grease on the new axle splines before installing it. Then slide the new axle through and bolt everything back up. Use some locktight on the axle locknuts if you don't have a locking axle nut.
