2001 Blaster Oil
Old May 27, 2010 | 11:11 PM
ccolt1's Avatar
Default 2001 Blaster Oil
I was wondering what oil I use for the transmission? I would like to change it this weekend and would like to use a good oil. How much does it take? Do I fill to the top of site glass? Thanks for any help!
Old May 29, 2010 | 11:16 PM
91Warrior357's Avatar
there should be a little line engraved on the side of the case....kinda hard to see but you fill it up on level ground till its even with that mark, they take like 10w30 motor oil or 80w 90 gear oil, Rotella diesel truck oil works good too, dont use dexron though, Castrol, Yamalube are good the best one i know of is Bel-Ray gear saver but its pretty expensive.
Old May 30, 2010 | 01:47 AM
ccolt1's Avatar
Thank you for the reply! I will try the castrol. Will gear saver work in the palce of 10w30? I would like to use whatever would make it last longer. Also do you you shift without using the clutch after you start out for speed shifing or do you use the clutch? thanks
Old May 30, 2010 | 10:26 AM
10w30 and 80w90 is about the same viscosity and the Bel-Ray Gear Saver oil is definitely the best oil you can use for a blaster imo but alot of the others will do just fine, ive always used the clutch, the only time i dont use the clutch is sometimes on long wheelies, when i speed shift i basically just like feather the clutch only like quick 2 finger pulls or sometimes on certain bikes i would kill switch shift lol, hold it wide open then hit the kill switch and shift, instead of havin to let off the gas or pull the clutch in, but that was just messing around on old dirtbikes.
Old Jul 14, 2010 | 01:08 AM
blaster777's Avatar
when u fill it ride it for a tiny bit then checkit againonce its workedin the gears u mite not have put more in but i did when i changed my oil in my blaster
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Ahtatu
Sep 28, 2015 12:14 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
