More MOTO 4 Help needed PLEASE
Old Jul 24, 2010 | 03:47 PM
BobUrban's Avatar
Default More MOTO 4 Help needed PLEASE
OK - I thought I had a bearing issue in the diferential and got enough information to get the axle out and take a look. That sucker looks brand new inside - and when it is off the bike it spins smoothly. I looked up into the drive shaft case and that all looks perfect too? Like brand new. So now what?
With the axle all hooked up the tires will not turn - maybe an 1/8 of an inch in forward or reverse and I can shift through the gears and the bike idles higher in neutral than in gear so I know it is shifting but the wheels will not turn?
Transmission? Linkage? any advice and if so where do I begin.
Thanks for any help.
Bob Urban
Old Aug 11, 2010 | 12:48 PM
318motorsports.com's Avatar
try the clutch area of the motor, maybe something not clamping down like it should to help turn the driveshaft.
Old Aug 20, 2010 | 06:01 PM
budd68's Avatar
it sounds like your reverse shifter is stuck in between gears.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
sara durrant
Jul 6, 2015 05:32 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
