carb problems
Old Aug 8, 2010 | 03:29 PM
buckshout1's Avatar
Exclamation carb problems
now my bruin has sat for about 2 years. when i spary starter fluid into the air box the atv will start for 3 seconds. if i empty the old gas and just spray some cleaner into the carb could this nelp it to run. need help please thanks
Old Aug 8, 2010 | 05:21 PM
Terrellster's Avatar
Definitely clean out the tank..... 3 yr old gas is typically bad and will gum things up anyway...... You may end up having to remove and clean the carb out very carefully to get things to perform correctly..... maybe a carb rebuild kit would be a good idea at this time too.
Old Aug 8, 2010 | 05:54 PM
91Warrior357's Avatar
yea definitely clean the tank and carb really good.
Old Aug 9, 2010 | 07:56 AM
nivrenor's Avatar
2 years? You definitely have to clean the tank and carb! Watch out though, since it was out for two years, you might have to change some parts of your bruin (i.e. gaskets).
Old Aug 9, 2010 | 08:02 AM
TLC's Avatar
TLC
Heres how you clean a carb,Disassembly and Cleaning of a Mikuni Round slide Carburetor its a Round slide not a CV carb but it gives you the idea.
Old Aug 9, 2010 | 09:19 AM
DODGE57HEMI's Avatar
Mopar Man!
Even after cleaning your car and gas tank I would still run Sea Foam though it!
Old Aug 11, 2010 | 08:05 PM
buckshout1's Avatar
ook i got her running and she runs pretty good haad to take the tabk out and judt got some carb cleaner judt worked it in the carb it cleaned it fine.when first road was a little slow to take off but now works great but one major problem the oil seal behind starter pully behind the pull starter. do you think im going to have to pull the whole caseing off. and does the oil seal have to be sealed.
Old Aug 11, 2010 | 10:16 PM
Mopar Man!
Good deal! Glad you got running again!
Old Aug 11, 2010 | 10:29 PM
buckshout1's Avatar
Yea I was so stoked when it started but I will not ride it until I put the new oil seal on. It's worth the wait. Don't wanna freeze it up again. Thicken about getting either the grizzly 550 or sportsman 550. But idk hard choice.
Old Aug 16, 2010 | 06:41 AM
nivrenor's Avatar
Wow! Good job bro. Good to hear that your atv is up and running again.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
