97 timberwolf
Old Oct 7, 2010 | 07:15 AM
bowranger's Avatar
Default 97 timberwolf
front output seal on the middle gear assembly is leaking. to change seal do you have to take the hole thing apart or is it like a car and just take the yoke off and replace that way?
Old Oct 8, 2010 | 12:52 PM
bowranger's Avatar
any body able to help
Old Oct 8, 2010 | 01:32 PM
TLC's Avatar
TLC
My friend did the rear output shaft on a 350 Big Bear, I don't remember him having to taking the whole thing apart.
I would change it(#8) from the outside using this screw trick.
Old Oct 8, 2010 | 01:34 PM
2cycletriker's Avatar
Check out this link
Yamaha of Troy
From the exploded view it looks like the seal is installed from the inside of the case, but sometimes the exploded views can be a little deceiving. I can't imagine having to take the entire thing apart to replace the seal but I have seen stranger things. Sorry, I have never had to service that particular part of a Timberwolf so I can't say for sure. Hope this helps a little.
Old Oct 8, 2010 | 01:39 PM
TLC's Avatar
TLC
Opps my view (#8) was the rear output seal ,sorry. No matter, from the above link it (#44) looks to be changed from the outside.
Old Oct 10, 2010 | 01:25 PM
bowranger's Avatar
i am looking at #39 seal
Old Oct 10, 2010 | 03:15 PM
Yeah, that is the one (39) that I was referring to as well based on your first post. The exploded diagram makes it look like the shaft, bearing, seal, etc are all installed from the inside of the case. However, experience has shown me that these diagrams can sometimes be deceiving and having never worked on that particular part of a Timberwolf I cannot tell you how it is actually assembled. My advice is to take off the yoke and see. I'm inclined to believe that the seal is installed from the outsde but I don't know for sure. Good luck.
Old Oct 11, 2010 | 08:07 AM
TLC's Avatar
TLC
If Worst comes to worst it looks like only ten small bolts to get the #36 plate cover off.
wildbill59
Jun 22, 2015 09:22 AM
wildbill59
Jun 9, 2015 02:28 AM
atc350
Jun 27, 2000 11:48 AM
95TimberWolf
Mar 14, 2000 10:33 AM
Brian_Kimmel
Aug 9, 1999 02:24 PM
