'01 Grizzly 600 recoil starter rope not retracting???
Old Mar 6, 2011 | 09:09 PM
atomicjoe23's Avatar
Default '01 Grizzly 600 recoil starter rope not retracting???
I have an '01 Grizzly 600 and the recoil starter stopped releasing. . .no big deal I think, so I pulled it apart and the spring for the ratchet pawl is decimated and the retaining nut that attaches the friction plate to the starter drum/sheave had come undone.
I ordered a new spring, put everything back together, and re-installed the recoil starter and it still won't release. . .I didn't know the exact orientation of the parts since the retaining nut had come off (I'm using lock tight once I know it's fixed), but I have a service manual (which doesn't do a very good job of illustrating part orientation) and I tried it with the pawl in two different orientations with the same results both times. . .I pull on the starter rope and then it won't retract. . .
. . .has anyone else ever had this problem?
If so, what did you do to fix it?
I've kinda exhausted what I know to do. . .I've even stoned the pawl smooth thinking that maybe the slightly rolled edges were preventing the pawl from swinging into the release position. . .anyway, that seems to be the problem. . .the pawl is locking out and not releasing.
Thanks!
Old Mar 13, 2011 | 03:44 PM
venn1979's Avatar
I have a manual. If you send me your e-mail address i'll sent it to you.
Old Jan 10, 2012 | 07:14 PM
I should have posted up sooner, but I got this problem fixed. . .although now I can't remember what I did to actually get the recoil starter to work again. . .
. . .I think I did some file fitting, but I can't remember other than that.
rawbdiggity
Sep 7, 2015 12:05 PM
Pahuntman
Sep 5, 2015 11:07 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
WesTech
11
Aug 11, 2015 07:55 AM
Desimation2k8
Jul 17, 2015 12:37 AM
