Warrior 350 Rev Problem
I have a 1995 350 Warrior and it had been sitting for a while and I am trying to get it running again. The problem is that when I am at normal idle speed (just sitting in nuetral) and I pin the throdle wide open it bogs out, if I keep it pinned then it dies, but if I let off it goes back to normal idle speed. I can hit the throdle hard half way and it revs up fine. It starts fine and idles fine, I have changed the fuel filter, changed the air filter, put a carb kit in it, cleaned the carb completely out, cleaned out all the jets, it has a new fuel **** assembly, cleaned out the gas and put new gas in it and still can't figure out the problem...?
