clutch kit/ 700 grizz
![Cool](https://atvconnection.com/forums/images/icons/icon6.gif)
ok guys i've been doing a lot of reading , and i need some straight answers. i want the most aggressive clutch kit i can get without a stall/start. "i dont want it to be hard on the bike"
i just have 27 10 front 12 back , inch swamp lites , and stock for now, can anyone help me out?
I suppose you could look at the Highlifter site, they are big on 'Monster" tire and clutch kits, if you use a kit designed for bigger tires than you have, it should grab and pull a lot harder than a kit for smaller tires, but you will lose top end, and it won't be as "rideable" in slow technical sections like when you are going over rocky areas or crawling over stumps and logs. Having it real aggressive is great for racing, pulling, or mud bogging, but not the ideal set up for trail riding. You didnt mention what you will be using the quad for, so I can't make a solid recommendation on what is best for you.
