Warrior problem ..
Old Apr 17, 2011 | 08:03 PM
osvaldo5245's Avatar
Default Warrior problem ..
So i installed a new intake manifold boot on my warrior and overnight it ripped ..anybody know why this happen...I feel like the carb sits up way to high but there's no other way to lower it since the air box hose has to be connected to the carb ...
Old Apr 17, 2011 | 08:12 PM
atvkiller's Avatar
does it look like the same boot that you had on there before iv never heard or seen this happen
Old Apr 17, 2011 | 08:24 PM
yes it looks exactly like the old one ..the carb looks like it sits up way high so when I push it down to plug in the air hose I guess the pressure rips it but that's the only way to make it work
Old Apr 17, 2011 | 08:41 PM
atvkiller's Avatar
i know some times those boots are formed a certain way so it angles for clearence just maybe it not in the right position mine on my can am is that way
Old Apr 17, 2011 | 08:46 PM
Maybe the intake boot was really cheaply made can't think of anything else
Old Apr 17, 2011 | 09:01 PM
atvkiller's Avatar
ya they are and what they charge is not right they charged me 30 bucks for mine then i had to replace rubber hoses on snorckle and they wanted20 for each so i just used some jet ski exhaust tubbing and it worked good i have put it under water 4 times sence i replace them and no leaks
Old Apr 17, 2011 | 10:05 PM
95wolv's Avatar
It is made at a slight angle, so it can be installed upside down, it has a little arrow that should point up, if mounted upside down, and the intake hose put on, it would put a lot of down force on it, and engine vibration could cause it to fail. take a close look and see if that is the case, I have replaced one of those on my Wolverine in all the years I have owned it, and I replaced it with a used one from eBay, years later, no problem. So double check the side of the rubber to see if you can spot the little arrow.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
