clutch help
Old May 16, 2011 | 07:21 PM
jamesa's Avatar
Default clutch help
Working on my 2005 blaster clutch lifter arm trying to get it ougt to replace it. Has anyone ever done this I'm not sure where to start with it or even how to get it out already bought parts just need to get it together. Help please
Old May 16, 2011 | 07:59 PM
Terrellster's Avatar
Shift lever or Shaft assembly? Not sure what you mean by lifter arm.
If you go to the Yamaha Website and look under Shift Shaft in the parts diagrams, it pretty much explains it in the picture..... Nothing schmancy on this one.
Shift Lever, remove clamping nut and bolt from Lever-to-shaft clamping collar. Spread clamping collar a little, slide shift lever off shift shaft. It's important to remove the entire bolt and nut, as they also interfere with the lever coming off.
To remove the shift shaft, there's a lot more to it. This is where I back away and let you consult a manual for proper break down and re-assembly.
Old May 16, 2011 | 08:38 PM
jamesa's Avatar
I meant the clutch actuator arm I will check out a yamaha web site thanks alot
Old May 17, 2011 | 06:47 AM
Ah,.... Sorry,... I wasn't much help.... Sounds like a case-splitting exercise now for sure.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
